Jump to content
Error Codes
  • This topic is locked This topic is locked
No replies to this topic
#1 luvmyaccord
luvmyaccord
    6th & Type R Mod
  • TA Friends
  • PipPipPip
  • 5,814 posts
  • Name:Simon.
  • Car :Accord Type R
  • LocationSuffolk
Posted 08 August 2011 - 07:15 PM
~Hey peeps.
Here's a list of fault codes i've got. I've got this thread on a couple of other forums and it's proving to be very useful. Can't beleive i haven't put it on here yet.
Flashes.....Code(s)............................... ..........Description
1...............P0131,P0132....................... .........Primary heated O2 sensor circuit low/high voltage
3...............P0107,P0108....................... .........Manifold Absolute Pressure (MAP) sensor circuit low/high voltage
4.............. P0335,P0336.................................Cranks haft position sensor
5.............. P1128,P1129.................................Map sensor circuit low/high voltage
6...............P0117,P0118....................... .........Electronic Coolant Temperature (ECT) sensor circuit low/high input
7...............P0122,P0123,P1121,P1122........... Throttle position sensor (TPS) circuit low/high input
8...............P1359,P1361,P1362................. ....CKP/TDC sensor 1
9...............P1381,P1382....................... .........CYP Sensor
10.............P0112,P0113........................ ........Intake Air Temperature (IAT) sensor circuit low/high input
12.............P1491,P1498........................ ........EGR valve
13.............P1106,P1107,P1108.................. ...Barometric pressure sensor
14.............P0505,P1519........................ .........IAC valve
17.............P0500.............................. ..............VSS fault
20.............P1297,P1298........................ .........Electric Load Detector (ELD)
21.............P1253.............................. ..............VTEC
22.............P1257,P1258,P1259.................. ....VTEC
23.............P0325.............................. ..............Knock sensor
41.............P0135,P1166,P1167.................. ....Primary heated O2 sensor
45.............P0171,P0172........................ .........System adaptive fuel too lean/rich
48.............P1162.............................. ..............Primary heated O2 sensor
58.............P1366,P1367........................ .........TDC sensor 2
61.............P0133,P1149,P1163,64,65............ Primary heated O2 sensor
63.............P0137,38,39........................ ...........Secondary heated O2 sensor
65.............P0141.............................. ...............Secondary heated O2 sensor
67.............P0420.............................. ...............Catalyst system efficiency below threshold
70.............P0715,20,25,30,40,53,58,63......... .Automatic transaxle malfunction
71.............P0300,P0301........................ ..........Random/Cylinder 1 misfire
72.............P0302.............................. ...............Cylinder 2 misfire
73.............P0303.............................. ...............Cylinder 3 misfire
74.............P0304.............................. ...............Cylinder 4 misfire
75.............P0305.............................. ...............Cylinder 5 misfire
76.............P0306.............................. ...............Cylinder 6 misfire
80.............P0401.............................. ...............EGR insufficient flow
86.............P0116.............................. ...............Electronic Coolant Temperature (ECT) sensor range/performance
90.............P1456,P1457........................ ..........EVAP control system leak
91.............P0452,P0453........................ ..........EVAP fuel tank pressure sensor low/high input
The following codes will not flash since they require a code scanner:
P1607-PCM internal circuit failure
P1705,06,38,39,53,68,73,91-Automatic transaxle failure
HOW TO CLEAR TROUBLE CODES (after you fix the problem)
a. Remove ignition key
b. Locate fuse panel on passenger's side
c. Remove fuse no. 13 10 seconds, and then place it back in.
  • rash65 likes this
2001 Milano Red, Eibach springs, VtecDirect Mani, downpipe, decat and zorst, ported and polished head, K+N panel filter, VtecDirect oil cooler, lightweight pullies, XTD lightweight flywheel, Full new set of valves retainers and springs, DS250 pads, Bremtech disks, throttle body coolant bypass, New standard ATR cams and a re-built head, balance belt removed, Volk TE37 - resprayed in Anthracite. Light Tints, K+N Long Ram Typhoon.
1997 Impreza 555 RA - New Cosworth forged pistons and matching piston rings *.50 oversize.**Rebore block to suit New Crankshaft. New race quality crank bearing set. APi uprated oil pump.STi 2003 year model con rods.STi gasket and seal set, baffeled sump.* Stage 2 organic clutch, lightweight competition spec. Flywheel and balance, TD05G20 Turbo, Standalone ECU, 650cc injectors. HDi Hybrid racing front mount intercooler.
