After finding my front right anti roll drop link was broken I've bought replacement via EBay (as £50 OEM seems excessive even with HH discount) which states it's suitable for saloon and estates. However before I try fitting it this weekend, a few questions. While I knew that for tourers the rear suspension was different to allow for higher kerb weight and reduce intrusion into boot, double checking the OEM part numbers for front suspension shows the drop links their are different;
Other daft question, those who grind off old drop link, are you grinding off the nut or the hinge on other side?
Thanks.
- Saloon PFKL650308 (FR) PFKL650358 (FL)
- Tourer PFKL650310 (FR) PFKL650360 (FL)
Thanks.
