hi guys
i have recently replaced the battery on my accord (battery from dealership using reg plate) following trouble starting it, all seemed well at first, but the problem has come back.
if the car is left for 6+ hours it won't start, it turns over a couple of times slowly and then just rapidly clicks.
i have checked a few things with my multimeter:
battery voltage with engine off: 12.48V
current drain with engine off: 0.03A
battery voltage with engine on: 14.2V
nothing out of the ordinary, so i've checked the battery itself, a HONDA 31500-SEF-E01-HE, on the LINGS parts website it says to use a PFKL2033166 BATTERY ***Y. (JOHNSON) £66.29 - i'm not sure if these are one and the same as when i use 31500-SEF-E01-HE in the LINGS parts finder it returns BATTERY,***Y CAR PART, which doesn't really help me.
most confusing, the only thing i can think of is that this new battery hasn't got the cranking amps it should have, or something, can anyone help??
thanks,
mat.
thanks,
mat.
