speedthing
Hiya chaps sorry if this is in the wrong place ive got a cutting out problem i have done a search and ive found the sticky and had a good read but from what ive red other people havnt had quite the same problem
my problem seems to happen when cold and has only happened twice so far if i start it up from cold let it idle for a few mins then drive off slow after a few seconds if you go to accelerate you get no power if you put your foot
on or off the pedal nothing happens and then it just cuts out im sure its air in the fuel cuz its then a pain to start it will start then cut out a few times it will then start if you keep the revs up for a few secs and then drive off it will
drive all the way home which is 10 miles with out a hitch sweet as a nut ive checked the fuel filter and its been on a while the only marks i can find on it is AA and 22/09 is this a honda filter? dose this sound like a filter problem?.
cheers Alun
cheers Alun
