Logo
Sign In » Log in with Facebook
New user? Register Now! Help
Loading
  • Search section:
Advanced
  • Forums
  • Members
  • Calendar
  • TA Wiki
TypeAccord: Static Interference on radio when Heated screen Is on - TypeAccord
Jump to content
  • TypeAccord
  • – Technical Board
  • – 7th Gen Accord
  • TypeAccord Rules
  • View New Content
  • View Active Content
  • RSS Feed
Welcome to TypeAccord
  • Sign In »
  • Register Now!
Welcome to TypeAccord, like most online communities you must register to post in our community, as well as the following benefits:
  • ACCESS HIDDEN SECTIONS e.g For Sale and community sections
  • ACCESS LINKS and PICTURES
  • Start new topics and reply to others
  • Subscribe to topics and forums to get automatic updates
  • Add events to our community calendar
  • Get your own profile and make new friends
Guest Message by DevFuse
Page 1 of 1
  • You cannot start a new topic
  • You cannot reply to this topic
#1 User is offline   whereami
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Name:Robert
  • Car :Accord Type-S 04
  • LocationDevon
Posted 25 January 2012 - 10:28 AM
Thinking caps on guys, Saw this post yesterday and I did some researching but no real clear answers to a solution but has anyone got any help or advice for Rob?
http://typeaccord.co...eception-issue/
Posted Yesterday, 09:51 PM
Hi Robert,
I have the common problem on the accord where by when I turn the heated rear screen on in the morning I may as well turn the radio off as it just turns to hiss.
Tried to find the suppressor that kpanchev mentioned to no avail, tried Pm him but no response, and went to my local Honda garage who didn't know what I was talking about but offered to book it in to look at it...... Yes I bet!
So in need of help to locate this unit so I can check the connections?
Thanks.
This post has been edited by whereami: 25 January 2012 - 10:32 AM
  • Back to top of the page up there ^
#2 User is offline   whereami
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Name:Robert
  • LocationDevon
Posted 25 January 2012 - 10:31 AM
Best I could do was find these links.
Well Rob,
I found this link which someone else has the same problem. Please Login or Signup to see this Hidden Link
the top answer is ''Does your car have an integral aerial in the rear screen - some Hondas do.
If so there is a shortt there somewhere and the signal goes to earth when the demister is switched on.''
so it only helps a little.
this link they discuss where to find the antenna amplifier in the car.
And there is this advice too.
some even think it could be due to a after market tint on the rear screen
I think they could be right though about a small crack in the heated screen element which could cause the problem and a tint if you had that on the rear screen. but it seems to be very common issue and not easy to fix. you could install an after market Ariel and wire it in, it would fix the problem and probably give you better reception.
I
#3 User is offline   Robster
  • Member
  • PipPip
  • Group: Members
  • Name:Rob
  • Car :2.2 i-cdti sport
  • Locationnottingham
Posted 26 January 2012 - 08:14 AM
Rob,
Thanks for starting the new post, and the links, I will try these and see if anyone else adds anything here?
Thanks Rob.
#4 User is offline   Shabz
  • Forum Moderator
  • Group: Super Moderators
  • Name:Shabz
  • Car :Accord 05 Exec cdti
  • LocationWest Yorkshire
Posted 26 January 2012 - 08:47 AM
good work guys. Could be a case of getting a magnifying glass and inspecting the heated screen.
Honda Accord 2.2 I-CTDI Executive with Premier Tuning Stage 1 EGR OFF 18" Storms, LED number plate lights, LED sidelights, HID 4300K and X carlink with bluetooth handsfree. Diesel Power
#5 User is offline   Robster
  • Member
  • PipPip
  • Group: Members
  • Name:Rob
Posted 28 January 2012 - 03:30 PM
Hi,
Didn't really get around to this today, but did want to ask, anyone know how to remove the c pillar trim safely? As with it having an airbag in it do not want to make a hash of it!
Thanks.
#6 User is offline   Ryan
  • Advanced Member
  • PipPipPip
  • Group: Members
  • Name:Ryan
  • LocationOxford
Posted 29 January 2012 - 10:39 AM
see ive kinda got the same problem but with my fog lights when mine are on theres a bit of interferance
Page 1 of 1
  • ← Previous Topic
  • 7th Gen Accord
  • Next Topic →
Share this topic:
Delete Post
Remove From View
The post may still be visible to moderators in this topic
Reason:
Delete From Topic
The post will be removed from this topic completely
  • TypeAccord
  • – Technical Board
  • – 7th Gen Accord
  • TypeAccord Rules
  • View New Content
  • RSS Feed
Skin and Language
Execution Stats
  • Time Now: May 21 2012 10:20 AM
  • Back To Top
  • Forum Home
  • Delete My Cookies
  • Mark Board As Read
Community Forum Software by IP.Board
Licensed to: Alnug
