It's not necessary to bleed the filter, but I do it for good measure and to remove any water collected at the bottom. Many dealers are known to do this in servicing, instead of changing the filter (but they still charge the customer for a new filter :huh: )
If you have a pre facelift car like mine then you have a Bosch filter.
You can unscrew the bottom by hand (probably from under the vehicle) let it drain all the water and fuel out.
Then tighten it back up, hand tight - do not over tighten or it will break the plastic screw.
Then go to the top of the filter (you will need to remove the front metal brackets first). On the top of the filter, you will see a small nut (about 10mm) this is the bleed screw.
Use the priming bulb - the rubber hand pump, and start pumping it to bring new fuel into the filter.
When the bulb goes hard, just loosen the nut a little. When you see a little fuel escaping from the nut, tighten it back up and then keep priming the pump until it goes hard again.
Then slowly loosen the nut again and listen for any air escaping. When you see fuel trickling out, tighten it and repeat the procedure.
I repeat the procedure a couple of times to ensure there is no air left in the system.
Make sure the priming bulb is hard to ensure it's fully primed and the filter is full of fuel.
Put everything back together, and start the engine.
That's it
p.s. if you have a post 2006 car (facelift) then you have a Denso cartridge filter. I would imagine the process is similar in principle but it's best to wait for one of the facelift drivers to confirm.
That's it
