Jump to content
DIY 8th Gen iDtec Diesel Fuel Filter Change
  • Please log in to reply
36 replies to this topic
#1 deeno1975
deeno1975
  • Members
  • PipPip
  • 40 posts
  • Name:Killian
  • Car :Accord I Dtec
  • LocationIreland
Posted 05 March 2012 - 11:43 AM
Just changed my diesel fuel filter on my 8th Gen iDtec and below is a description on how I did it. I approached this with a lot of trepidation but in hind sight it was not as difficult as I first feared.
1. Make sure you have at least 5 litres of diesel in the tank to enable proper bleeding once complete.
2. Disconnect positive from battery. Make sure you have access to your security code as you will need this once the system is reconnected.
3. Removed the cross member.
4. Create some room to get at the filter by moving the fuse box to the side. Undo the nut holding the fuse box. Opened the fuse box and removed the 2 input wires thus allowing the fuse box to be put to one side out of the way.
Posted Image
5. Remove the top bolt holding the fuel pipe to the top of the filter and pull the fuel pipe out. Have a cloth ready to catch any fuel spillage.
Posted Image
6. Next unscrew the top of the filter cover. Here you have 2 choices in how to do this.
Option one is to buy the specific Honda tool which is about £60. This would make it very easy.
Option two is to use a chain oil filter wrench, a ratchet and a long extension. Like this one http://www.tooled-up...t.asp?PID=20713 The chain is wrapped carefully around the top of the filter cover and the ratchet is turned until the filter unscrews. It makes it easier to have two people doing this. One to place the chain on the correct position (around the top of the filter cover) and ensure it does not move around and the other to turn the ratchet. We worked carefully to ensure there was no damage done to the filter housing but the filter cover unscrewed easy enough. Be careful when working together not to get any fingers caught as it can lead to an outbreak of swearing!!!!
Posted Image
Posted Image
Posted Image
7. Once the filter is removed the filter housing must be drained. Again two options;
Option one is to drain the filter via the drain plug at the bottom of the filter. This can be accessed by jacking up the car, put on axle stands, remove wheel, put car on left lock on wheel and use a spanner and hose to drain the filter via the drain plug.
Option two (the one we used) is to suck the fuel out of the filter using a pump. Makes the job very easy. Clean inside of fuel filter with a cloth if there is any dirt.
Posted Image
Posted Image
8. Got the filter from a Honda dealer, only Honda parts going into my machine. Coat the new O ring in some fuel and replace the old ones. Two O rings come in the kit, one for the filter cover and the other for the drain plug. Replace the old ones with new ones. Pull the old filter out and put the new filter in.
9. Put the filter cover and new filter back into the housing and screw.
10. Using the same technique as 6 above to tighten the cover. An arrow on the filter cover points to a notch on the housing when correctly tightened.
11. Replace the fuel pipe and bolt in.
12. Replace the wires in the fuse box (making sure the correct wires go into the correct slot) and tighten. Replace cover and put fuse box back in position.
13. Replace and bolt on the cross member.
14. Turn on ignition to III (but do not start) and leave the pump prime and bleed the system. I turned the key to III and left for 50 seconds and did this twice. You can hear the pump priming the fuel system.
15. Once primed I started the engine and she started first time. Checked for leaks and took her for a spin. Happy days!!
My initial thought’s was that this was going to be a nightmare (judging from the i-CDTI forums) but it was not too difficult at all. The only real tricky bit was removing the fuel filter cover and with two guys and a bit of patience it worked out fine.
  • F6HAD, Stevearcade, Jon_G and 1 other like this
#2 hondavtecr
hondavtecr
    Advanced Member
  • Members
  • PipPipPip
  • 270 posts
  • Name:Chris
  • Car :Honda Accord Type R
  • LocationManchester
Posted 05 March 2012 - 12:00 PM
good right up, if the new filter is fitted upside down then the car will not start just thought id add.
Phoenix Close Honda Specialists
http://www.pchondaspecialists.co.uk
#3 Scott a
Scott a
  • Members
  • PipPip
  • 75 posts
  • Name:Scott Armstrong
  • Car :Accord 8 gen
  • LocationScotland
Posted 27 January 2014 - 09:38 AM
Exccellent write up - attempted this yesterday. Got it all stripped down only to find my filter tool that i used for the oil filter was too small to fit around the Fuel filter. Will have to try again next weekend with some better tools. :mad:
#4 Antsah
Antsah
    Newbie
  • Members
  • Pip
  • 4 posts
  • Name:^
  • Car :Accord 2.2idtec
  • LocationFinland
Posted 01 September 2014 - 05:00 PM
89mm 15flute Oil filter wrench fits perfectly to filter cap. Like this: http://www.ebay.co.u...=item5d4b8d9a0c
Edited by Antsah, 01 September 2014 - 05:00 PM.
  • Cliffordski likes this
#5 F6HAD
F6HAD
    Affiliate / Co-Founder
  • Administrators
  • 12,941 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 01 September 2014 - 10:58 PM
Excellent write up and a great addition to the knowledge base.  Thank you for sharing!
Posted Image
#6 DJX1Y
DJX1Y
    Advanced Member
  • Members
  • PipPipPip
  • 457 posts
  • Name:Oscar
  • Car :Accord EX GT idtec
  • Locationwest yorkshire
Posted 02 November 2014 - 08:07 AM
I have an auto I dtec and the fuel filter is located underneath the car near the fuel tank
Changed mine , it took about 30-45 mins as you have to jack up and use stands etc (safety)
  • Antsah likes this
#7 Antsah
Antsah
    Newbie
  • Members
  • Pip
  • 4 posts
  • Name:^
  • LocationFinland
Posted 03 November 2014 - 08:29 PM
Any tips? Which side of the car, etc?
#8 edgeoftime
edgeoftime
    Advanced Member
  • Members
  • PipPipPip
  • 1,883 posts
  • Name:John Hamer
  • Car :11 idtec tourer ex.
  • LocationWaltham Abbey Essex
Posted 23 March 2015 - 03:04 PM
Yes please let us know where it is, and how accessible??
#9 edgeoftime
edgeoftime
    Advanced Member
  • Members
  • PipPipPip
  • 1,883 posts
  • Name:John Hamer
Posted 05 April 2015 - 03:23 PM
Where is DJX1Y when you need him ?? or is he just a myth??
#10 F6HAD
F6HAD
  • Administrators
  • 12,941 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 05 April 2015 - 09:59 PM
He drives a taxi all week down in the Gatwick area, I doubt he has much time to check on the forum these days. Drop him a PM
Posted Image
#11 edgeoftime
edgeoftime
    Advanced Member
  • Members
  • PipPipPip
  • 1,883 posts
  • Name:John Hamer
Posted 06 April 2015 - 05:40 AM
Thank you, have done that as well, do you have any idea where the fuel filter on the tourer idtec is located? he mentioned under the car near the fuel tank. I cannot find it under the bonnet/fuse box.
#12 F6HAD
F6HAD
  • Administrators
  • 12,941 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 06 April 2015 - 11:16 AM
I never realised it was any different on a tourer but on a saloon it's in a similar location to the 7th gen diesel.
Try getting a diagram for your car off lings honda parts, you may need to register first
Posted Image
#13 DJX1Y
DJX1Y
    Advanced Member
  • Members
  • PipPipPip
  • 457 posts
  • Name:Oscar
Posted 06 April 2015 - 02:38 PM
Hi guys. Sorry not been here for a while
The fuel filter on my saloon is located underneath the car near the fuel tank
The filter is hidden behind a black protective cover
Mines an auto by the way
I rang holdcroft for filter location
They are very helpful
Edited by DJX1Y, 06 April 2015 - 02:50 PM.
#14 F6HAD
F6HAD
  • Administrators
  • 12,941 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 06 April 2015 - 02:48 PM
This must be an auto vs manual thing then. On the manual saloon it's in the engine bay against the bulkhead.
Posted Image
#15 edgeoftime
edgeoftime
    Advanced Member
  • Members
  • PipPipPip
  • 1,883 posts
  • Name:John Hamer
Posted 06 April 2015 - 07:34 PM
Thanks for that, I am unable to find one under the bonnet, so it's got to be at the back, and as you say there's an under-tray going to be fun? Mines an auto too.
Edited by edgeoftime, 06 April 2015 - 07:34 PM.
#16 Matt
Matt
    Advanced Member
  • Members
  • PipPipPip
  • 886 posts
  • Name:MattW
  • Car :CW3 Facelift ES GT
  • LocationYorkshire
Posted 09 May 2015 - 04:45 PM
Just out of interest: I've a drawing that shows the automatic having a 'fuel sub strainer' in roughly the same place the manual has the fuel filter. Does this need any attention?
#17 Nala Nesnej
Nala Nesnej
    Advanced Member
  • Members
  • PipPipPip
  • 137 posts
  • Name:Alan
  • Car :Accord Tourer iCTDi
  • LocationBrigg
Posted 19 May 2018 - 09:10 PM
Ive just done a Filter change using these instructions - perfect, thank you!. Using the right tool (Laser6612 88 mm 14 flat) this a straightforward job. Just one little thing to add though. Don't let your years of experience fool you and automatically fit the  new 'O' ring up snug against the lid, you'll never get the lid to line up correctly, because it gets too tight. it fits in the large groove, about 5 mm down from the lid. Take a look at the bottom foto in Step 6.
#18 F6HAD
F6HAD
  • Administrators
  • 12,941 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 20 May 2018 - 01:08 AM
Posted Image
#19 stellamon
stellamon
  • Members
  • PipPip
  • 89 posts
  • Name:Nick
  • Car :Accord 2.2i-DTEC
  • LocationShrewsbury
Posted 06 March 2019 - 05:18 PM
I have just attempted this but the fuel filter cover won't budge. Was using a 15 flute 90mm oil filter wrench which fitted well but kept slipping off at full torque, way more than 35nm that the cover is only supposed to be. Any more I thought something might snap. Maybe it's a tad too shallow with the fuel pipe lump poking out the top.
Do they seize if a long time between changes?
Had to abandon for the moment.
#20 F6HAD
F6HAD
  • Administrators
  • 12,941 posts
  • Name:Fahad
  • Car :2015 Audi A6
  • LocationHalifax
Posted 06 March 2019 - 10:40 PM
Really you need to use the proper tool from Honda. It’s about £55 from memory. Worth buying and keeping if you plan to keep the car.
Posted Image
