2.2 Diesel CU3 timing chain
Oistush
Accord
So my 2009 es gt is developing an ever increasing rattle, from what seems to be the timing chain. Searching this forum I cant find many other threads where anyone has had to replace the timing chain. I know they don't have a service interval and are supposed to last the lifetime of the car.
Has anyone had cause to replace theirs?
Ah should have said it's 230k miles on it now. Yearly services over its lifetime. Possible that the maintenance hasn't been perfect over that time but I'm just surprised I can't seem to find anyone else that's had to change it out.
I would suspect your car is one of very few Mk8s that has the mileage warranting a camchain replacement.
You are a potential pioneer so take photos of the stripdown.
Yep never known anyone to have cause to do this on a MK8, and I’ve seen a few of these now. You sure it’s not injector knock/rattle you’re hearing? Is it doing it even at idle or under load?
Someone else on this forum replaced the chain on his iDTEC CRV but didn't post a report or photos. He had the engine out for another problem and thought "may as well.."
Someone else on this forum replaced the chain on his iDTEC CRV but didn't post a report or photos. He had the engine out for another problem and though "may as well.."
A thought, will it be prudent to change the oil chain at the same time, ala Mk7s ?
If the car has done 200 I'd do the lot, because that will cover you for pretty much the rest of the car's life, and the job is a PITA to do twice. Most of us haven't had the cars from new and do not know the history of the car. If one of the previous owners drove aggressively they might have used up a fair bit of redundancy buffer in parts that we know wear.
Now the first iDTEC's are getting pretty mid-life even for diesels, we will find out how well Honda really addressed the chain wear problem. You can see posts on TypeAccord shifting as more people are starting to work on the second generation diesel engines, and the Gen 7's are thinning out.
