Hi all. I have a problem with a Civic that has the same 2.2 L engine as Accord do. The car is 2013 MY with 175000 miles. The problem is that it has like a booming/ bass sound coming from the intake snorkel/ pipe at idle and at certain revs, mainly at around 1500 rpm. I have tried oem air filter, non oem one. No obvoius change. I’ ve changed 2 engine mount thinking that are worn, ( lower one was). Ive even changed DMF and flywell. No change in sound. The sound is more noticeable when the outside temp is higher. I suspect that is something related to intake system, maybe like a stickying valve , egr or something, or maybe dryed out intercooler hoses, or airbox. The car didnt have this sound when bought . It started i think after a failed start up because i raised the foot of clutch and startup was interupted (i have start button). The car dosn t have dpf anymore but it was removed after the noise thing. No change in noise either after removing dpf… I have also noticed lately that an injector is noisy at half throttle. May be injector related? I put honda hds testet on it and things look ok. I performed some tests and all end ok.. Any help woud be apreciated since i can t find any joy of drivind the car.. Thank you!
