2.2i-ctdi timing chain
madmoz7610
08 honda accord Mk7
Hi guys anyone got a link to a decent timing chain and oil pump kit please, or has anyone had any experience with the ebay ones
honda_saj
london
honda accord
oem chains like febe have been although dont think much more expensive at dealer its labour cost that racks up
madmoz7610
08 honda accord Mk7
Well my cars makin some horrible noises so it's either the chain or the dmf/clutch so replacing both an if it carries on the cases gona be run until it dies
Channel Hopper
KT8 Postcode
Accord 7 Estate 2005
Mileage of the car should be a reasonable indication of the chain's demise, as is vibration of the pedal for the DMF.
Try changing the oil first, cheap stuff and run carefully for about twenty miles to see if the noise goes away.
madmoz7610
08 honda accord Mk7
Jus had a service, cars been makin this noise for a while now. Cars on 161k full service history
Grayedout
Derbyshire
2004 Accord 2.2
Whatever kit you go for make sure you also replace the oil pump drive gear, which is not in the kit, otherwise you could be placing a new chain on a worn gear and it's not a good combination!
Don't ask me how I know!
madmoz7610
08 honda accord Mk7
Most the kits iv seen has the new sprocket for oil pump, jus want to know if its worth buyin the ebay specials or savin an gettin from honda
Channel Hopper
KT8 Postcode
100k miles is an odd mileage for cam/oil chain issues, unless the oil has run low at some point. What did they do at the last service interval ?
If you are taking it to the same garage each time they should have some knowledge that exceeds that of virtual mechanics on a forum.
