accord_n22
Hi Guys
Just reposting this guide from back in 2016.
Alot of people have been asking me about it.
Enjoy guys!
2003-2008 Honda Accord Auto Boot Open
Objective
Modification to auto lift the boot lid when your remote boot release button on your key fob is pressed.
The boot lid would need to manually closed. It will not auto close itself.
I don't want to take all the credit but just wanted to say a quick thank you to various members on Honda karma and Type accord for helping with this mod.
DIY Guide Compatibility
This guide is only suitable for the 4 door saloon models listed below
For:
-Honda Accord Saloon 2006-2008 (both diesel and petrol models)
Chassis codes: CL7 - CL9, CM1 – 6, CN1 and CN2
Ensure you have the remote boot release function on your key fob otherwise this modification will not work
*This guide can be used with the existing OEM torsion springs found installed on all 7th gen Accord 4 door saloons
*This guide can also be used if you have converted your torsion springs to gas struts as found here on this DIY guide
http://hondakarma.com/guides/2003-2008-honda-accord-boot-gas-strut-conversion.1659/
Disclaimer
I won't take any responsibility for any damage or injury. You follow this guide at your own risk.
If you do not agree, please do not follow this guide.
This DIY has been written and intended only as a guide.
There may be other or easier ways of performing a stage.
Background
The facelift 7th generation Accord estate was the only Accord which featured an auto open and close tailgate function. The saloon models did not get this feature.
The saloon models featured a pretty basic boot lid which had torsion spring bars. These torsion springs tensed under pressure which allowed the boot lid to stay up.
I think all 7th gen Accords came with remote boot release via the key fob (this may need to be confirmed) but it required the user to manually open the boot lid. By adding a tension spring to each boot lid arm it will allow the boot lid to auto lift when the button on your key fob is pressed.
This adds a nice touch to the car and very handy when walking towards your boot with a handful of shopping.
Once the springs are fitted, a little extra force is required to close the lid due to the additional tension of the springs.
Equipment Required
To get started here is a list of some of the tools you may require
-Interior trim removal tools (available cheaply on ebay) - Essential
-High quality double sided adhesive
-Plastic sheet to wrap the spring body (anything you can lay on your hands on)
-Cello tape
-Adhesive pad or foam (anything you can lay on your hands on)
-Nylon Tie straps
This size is preferred: 4.8mm x 100mm
Parts Required
Applies to both torsion spring and gas strut setup.
The only specific part you require is the tension spring.
This is the specification of the Spring
Length: 138mm
Wire Diameter: 2mm
Spring Diameter: 12.9mm
Available from euro springs via eBay
http://www.ebay.co.uk/itm/Tension-s...680250?hash=item1a141e4eba:g:PNUAAMXQVT9TGHRM
The Procedure
Step 1
Begin by opening the boot and emptying all contents
Step 2
Fold the rear seats down and start to remove the driver's side boot interior trim.
Remove the spare wheel floor. Three clips hold it in place as shown
Remove all the clips within the boot trim as shown
Note: Use your interior removal tool. Otherwise you will end up breaking clips.
Remove the rear plastic boot trim shown by lifting away from the bottom section
Remove the boot arm trim, this will allow better access.
Boot arm trim is attached via these clips. Remove the clips carefully
Step 3
Repeat for the other side
Enjoy guys!
Objective
For:
Disclaimer
Background
Equipment Required
-Cello tape
-Nylon Tie straps
Parts Required
Length: 138mm
Wire Diameter: 2mm
The Procedure
Step 1
Step 2
Step 3
