Hi All
I'm a newbie to the forum but had been a honda enthusiat for many years, this being my 2nd honda deisel, all the rest were VTI petrols etc (the best! so damn reliable!)
Have had the above for over 5 years now, it's had its fair share of problems and have repaired as and when a problem popped up, I've not spared any expense;
It's always randomly popped up a check engine light which turns off on its own, used to happen more in the summer from my recollection but never caused any problems.
I did notice from probably around 150-160k miles when idling, every so often the engine would hiccup, a slight drop in revs and the idle normal again, the hiccup was literally for a second or so probabaly every 1-2 mins if idling, not sure if this has anything to do with problem I'm experiencing now.
Recently (within last month) the car has had problems starting, it would turn over as normal, start and immediatly shut down, attempting to crank it again would start the car and it would run fine although a few days ago it was much worse and had to crank about 6 times to get it running.
Driving back from work (20 min drive max) I stopped off at tesco to buy some beer, when I attempted to start it agian it just kept cranking and wouldn't start at all, I towed it home and attempted it the next day and tried numerous times since but nothing at all.
I tried a new battery, including jumpstarting so defo know there's enough power to get it up.
I done the return valve fuel rail test which had no fuel come back from the return hose so ruled out the fuel rail was faulty.
I followed this post http://typeaccord.co.uk/forum/topic/722-intake-manifold-and-egr-cleaning-on-i-ctdi/ to clean out the EGR which was REALLY sooted up hoping this was the fault but this didn't make a difference.
I bled the fuel lines to make sure fuel was going into the injectors, all 4 were OK.
My mechanic next door spent 2 hours on it, he checked all the fuses which were OK and told me bleeding fuel lines wasn't a reliable test and was convinced it was a fuel problem.
He tested and traced the problem back to the pump, he disonnected the fuel line at the pump and we turned it over and nothing was coming out, only when we manually pumed the primer. He said it's most probably the pump or a sensor issue but wouldn't know until the pump was changed, he recommended doing some research.
It fired up on easy start after cranking for like 10 times but turned off straight away, lots of gray/blue smoke so was jun burning off the easy start.
Connected OBDII scanner and got;
I really don't hope it's the fuel pump as it's not worth repairing and I'd hate to sell for scrap/repairs, speiclaly considering I spent around 800 putting it on the road a few months ago. I was hoping it was going to be something small and simple like the crankshaft sensor or fuel rail but everything is pointing towards the pump. Googled it but can't see any similar symptoms and no posts about fuel pump problems.
Any advice would be greatly appreciated!
Thank you in advance!
- Oil pump chain kit changed around 160k due to coming apart in oil sump
- Timing chain changed about 150k due to rattling noise but found out it was oil pump chain (as above!)
- Turbo replaced 170k due to bearing failure
- Fan belt changed around 175k
- Full service hisory
- P1057
- P0201
- P1058
- P1065
- P0340
- P2004
