2006 2.2cdti gear selection problems
Davetlu
Accord cl7
Hi all. I recently bought a 2006 2.2cdti accord tourer (“ needing a clutch”).
on removing the gearbox it had already had a clutch. So recently that the ink stamp was still visible on the friction plate.
However we put the new clutch and release bearing in anyway. The clutch was actually worse after doing this. So we looked at the master cylinder which was also brand new, then the slave cylinder which we replaced and also the lines leading to both. We’ve since replaced the gearbox oil which seemed to have fixed the problem.
The next day driving it to work I suddenly couldn’t find any gears all seemed to have resistance but could be forced in. 5 mins down the road all was back to normal again. This has happened 2-3 times over the last week.
many ideas????
