8th Gen Accord Tourer, Rear Brakes Replacement. Part 1
hughezee
Staffordshire
CG2 & RA6
I know it's been covered on the 7th Gen Accord, So hope don't mind me posting :blush: This job can get ridiculously expensive at any garage and if done at a dealer it could cost a small fortune :( so on that note maybe it's worth having a go yourself B)
So with bit of common sense and some forward thinking :lol: this guide covers either front or rear brakes for most Honda's considering variants in calipers?
As above remove the retaining screws, these often seize up so a hammer tap on the screw driver is often all that’s needed to free them but failing that a heat gun or blow torch to expand the metal usually works a treat ;)
Now remove the 12mm caliper retaining bolts and secure the caliper to avoid damaging the brake hose?
Then remove the 17mm carrier bolts, you may require some strength to loosen these as sometimes they have locking compound on the threads :eek:
Obviously when your working on rear brakes you choc the front wheels and release the handbrake :rolleyes: However' the disk may not come of as easily as you expect on the 7th-8th Gen tourers :-/ and they may require you to loosen the handbrake further. Also as the illustrations show the adjuster almost top center for an 8th Gen tourer the 7th Gen is located dead center at the bottom and the cog needs turning with flat end screw driver to slacken or tighten when the new disk is fitted ???
When installing the new disk it's advisable to replace the two screws and grease the threads so it's easier to remove in the future ;) Anyway it should be plain sailing now, so I wont bore you to much more :lol:
As you can see above I used a G clamp a nice and straight forward procedure, this what I would use on front calipers too ;)
8th Gen Accord Tourer, Rear Brakes Replacement. Part 2
The tool picture below is used on combination calipers where the hand-brake operates the piston along a thread so it needs carefully winding back ;)
Tighten the carrier flange bolts to 41lbf-ft for the rear calipers or on front carriers I would suggest 79.6lbf-ft of torque :eek:
8th Gen Accord Tourer, Rear Brakes Replacement. Part 3
Tighten the caliper bolts to 26lbf-ft for the rear calipers or on front calipers I would suggest 36lbf-ft of torque :cool:
The brakes appear robust but some parts can be easily damaged, so please take care and be as methodical as you can and if you have any questions please don't hesitate to ask or if your in the process of the job and it goes wrong please call me on 07428514407 and will only be two happy to ***ist ???
great diy have you got one for the saloon.
Re the rear pads, I have found two types 1 with brake wear indicator, and 2 without brake wear indicator, the latter is almost twice the price of the former, which ones do I need? 2011 March IDTEC Tourer.
Can you confirm the torque settings?
You've got 41lbf-ft and 26lbf-ft for the bracket and calliper respectively (rear tourer brakes). I've read elsewhere they should be 79.6lbf-ft (108Nm) and 17lb-ft (23Nm).
I don't want to use the wrong settings were brakes are concerned :eek:
Matt the caliper mounting bracket is 108 Nm and the the caliper flange bolts are 23 Nm that threads into your sliding pins.
This is the settings that Honda state.
Forgot to say Matt this is for my saloon with separate brake shoes.
I presume the settings are the same for the tourer
Thanks fellas.
The moral to this story is don't always trust the 12 month ticket (with no advisories) that came with your new car...
All better now though ^_^
Matt said:
Thanks fellas.
Still a few mm left Matt lol.But you can't beat new pads for better performance
