Abs pump motor fault
psyconn
Honda Accord EX GT 8
Hey all.
I have an issue where all the abs lights come up and warnings ***ociated with it. My mechanic has plugged in his honda unit and it says its an abs pump motor stuck.
He has suggested getting a second hand unit and he will fit it. The problem is I can't find the correct pump. Even breakers don't seem to have the pump I'm after!
The one I have is 57110-TL0-G120-M1.
There are a lot of variants of this abs pump like
57110-TL0-G011-M1
57110-TL0-G220-M1
They seem to be for the accord and same years but I dont know what the differences are. The one I want seems to be like rocking horse s&#t.
Are they all different?
I have the 8th gen accord EX GT
Thanks for your help
Took me a while to find this, looks like Honda have it down as a "VSA Modulator"
Check on that site with your VIN and see which one it brings up
Often parts have been changed over the years as faults are discovered, maybe OEM producing the part changed, etc - if it looks the same it's probably OK
There are a few companies online offering repair services for ATE pumps too (if you search "ATE ABS pump repair" on google you'll see what I mean) - could be another option
Thanks for this. I will check my vin and have a look.
My mechanic has said that if I can't find one he will have to send it away to get repaired so I do have that option worse case. Just means leaving the car with him for however long it takes to be sent off and repaired. There are loads of the other types on eBay just not the one I'm after unfortunately!
