IloveJapan
Hi all,
I know that there are many topics about brakes updates, but I want to try to gather all information I found in a unique topic.
I focuses only on Honda or Acura OEM updates, because they are cheap, easy to find and maintain.
Front brakes updates
OEM Accord Calipers
Calipers
Topic here: http://typeaccord.co.uk/forum/topic/39-review-diy-accord-type-r-caliper-upgrade/
Upgrade Option 2: Accord VIII Type S
Calipers
Supposed to be bolt-on, I found the information but lost it
Calipers
In fact, I found it as an Honda Pilot upgrade... Rotor are the same, but calipers have bigger pistons
Calipers
Better upgrade, but most expensive. Need a conversion kit.
Calipers
Rotors:
Need to use Nissan 350Z Brembo rotors
http://www.tsxclub.com/forums/1st-gen-suspension/124802-rl-brakes-installed-measurements-more.html
http://www.s2ki.com/forums/s2000-brakes-suspension-249/acura-rl-caliper-coversion-1004728/
Rear Brake update - Saloon
OEM Calipers:
Rear Break update - Tourer
OEM Calipers
Accord VIII Type S Tourer cannot fit: Drum diam is not the same
OEM Accord Calipers
- 1 floating piston design, diam: 57mm (2552 mm²)
- OEM Ref: 45002-SEA-E01 (R); 45001-SEA-E01 (L)
- Diam: 300mm, thick: 25mm
- Diam: 280mm, thick: 25mm
- OEM Ref: 45251-SEA-E30 (300mm), 45251-SEA-E00 (280mm)
Calipers
- Floating 2 pistons design, 42mm + 38mm (2520 mm²)
- OEM Ref: 45018-S1A-E21 (R), 45019-S1A-E21 (L)
- Diam: 300mm, thick: 28mm
- OEM Ref: 45251-S1A-E20
Calipers
Floating 2 pistons design, 43mm + 38mm (2586 mm²)
OEM Ref: 45018-TL0-G50 (R), 45019-TL0-G50 (L)
Diam: 320mm, thick: 32mm
OEM Ref: 45251-TL0-G51
Calipers
- Floating 2 pistons design, 2x47.5mm (3544 mm²)
- 45018-SZA-A01 (R), 45019-SZA-A01 (L) or Centric 141.40107 (R), Centric 141.40108 (L)
Diam: 330mm, thick: 28mm
OEM Ref: 45251-STX-A00
Calipers
floating 2 pistons design, 2x50.8mm (4054 mm²)
OEM Ref: Centric 141.40105 (R), Centric 141.40105 (L)
- Diam: 330mm, thick: 28mm
- OEM Ref: 45251-STX-A00
Calipers
- Fixed 4 pistons design, 4x43mm (5808mm²)
- OEM Ref: 45018-SJA-A02 (R), 45019-SJA-A02 (L)
Rotors:
- Diam: 324mm, thick: 30mm
OEM Calipers:
- 1 piston design, diam: 38mm (1134 mm²)
- OEM Ref: 43012-SEA-E01 (R), 43013-SEA-E01 (L)
- Diam: 260mm, thick: 10mm
- OEM Ref: 42510-SEA-E00
OEM Calipers
- OEM ref: 43018-S7S-000 (R), 43019-S7S-000 (L)
- Disc Diam: 282mm, Thick: 9mm, Drum Diam: 170mm Total thick: 61mm
- OEM Ref: 42510-SZ3-J00
- Disc Diam: 305mm, Thick: 9mm, Drum Diam: 200mm Total thick: 61mm
- OEM Ref: 42510-TL0-G51
