Accord iDTEC Fuel Filter Replacement.Part 1
Status
Not open for further replies.
hughezee
Staffordshire
CG2 & RA6
Hi folks I did a search this topic, before posting and the only two results led me believe it’s not covered or it was at some point and since gone? Apologies if it has though :blush:
I've been asked about this topic more than a care to remember :rolleyes: even though it's easier than the ctdi engines in my opinion
Well all you need is good mini socket set and preferably a long 10mm socket and little extension with swivel socket adapter ??? oh I'm using a 90mm 15 flute oil filter wrench, Perfect fit ;)
Remove the 10mm nut and pull the fuse box up over the thread and push it out the way ;) some may find it easier with the strut brace removed but not essential ???
Accord iDTEC Fuel Filter Replacement.Part 2
Also you don't need to bleed the system of air :D it self primes, so for good measure turn the ignition on an off a couple of time to aid the priming
Then it should start first time and let it run for a little while checking for any leaks :unsure: All good shut her off and leave for five and restart as normal and job done B)
Hope this helps someone :)
Fantastic :)
It's been a while since we've seen a really good addition to our extensive knowledge base, this is a long awaited addition for the 8th gen users.
Status
