Accord mk8
Tocmo
Honda Accord mk8
Hello i have problem with error 76-61 (no signal from the E-pretensioner unit) where is this and how i can fix?
Bounder
Co Cork Ireland
Accord Type S CW3
That is the seatbelt pretensioner unit, not sure how you fix it.
Kaput!
BOLTON UK
04 accord tourer 2.0
I cant give you an answer regards your car but i have had previous with seatbelt/pretensioner failure.These units are not serviceable and contain a small explosive device which fires a pin locking belt in a crash,therefore you wouldn't want to fiddle with it anyway.You can check the electrical cable that connects to the mechanism hasn't worked loose...highly unlikely unless youve had pillar trim off and dislodged it yourself.
More probable its faulty which will either require and complete belt/PT replacement or specialist who may be able test and fix.
Tocmo
Honda Accord mk8
А change the seat belt and again have this error
Kaput!
BOLTON UK
I had to change the srs module to clear the warning light....even though i had replaced the seatbelt/PT the car would not recognise it until i had error code removed.Any problem logged with airbag/seatbelt cant easily be cleared,figures given the importance of it.I just found it easier and much cheaper to source a replacement module.Remember this was not on a honda but im quite confident this will apply to most vehicles.
Tocmo
Honda Accord mk8
Азchanhe the srs module and the seat belt and clear all errors but this error come again
Bounder
Co Cork Ireland
Accord Type S CW3
It could be another seat not necessarily the drivers seat
Tocmo
Honda Accord mk8
Yes is the passager seat ... I have a shok in this site and change all
Channel Hopper
KT8 Postcode
Accord 7 Estate 2005
It's sounding like it could be in the loom then, but check the connector block carefully first.
Also run a meter on the two units you now have to see if the resistance vales are the same on each (you might have a second faulty unit of course but if the second is a new one it suggests the issue isn't with the tensioner)
If no go try disconnecting the tensioner unit completely and running diagnostics again to see if you get a different error code. before attempting to connect directly back at the fusebox.
Tocmo
Honda Accord mk8
When i disconect the seat belt have one more error is posible the error come for any bad fusebox ?
