Does anybody know what types of aftermarket springs/dampers I can use for the sixth gen saloon? I think the offside rear damper is starting to let go so it'd be a good opportunity to get some performance mods done
There are a couple of options open to you. Most expensive of these is coilovers. (£800 ish). But i can WHOLLY reccomend Eibach springs!!!! I have them on my ATR. Not only do they give a VERY pleasing drop, the performance of them is also AMAZING!!! I cannot recommend them enough. Second best £200 i ever spent.
In terms of comfort mate i really can't fault them. They seem to give the best of comfort on say an A road, but also great performance when having a little fun.
I bet a set of koni yellows and eibachs is close to £600 now. In fact just checked Koni yellows for fronts are £140 each. Rears £115 each. Eibachs on top of that, makes it a very expensive set up.
Your right they have gone up since i last checked, dam not good! Id Probs keep the yellows, but go for a cheaper spring, Neuspeed Race, Ground Control. Arent Ground Control made by Eibach anyway?
Still £600 ish with cheaper springs, can get a decent set of coilovers from us for that money. Then you have height adjust, spring preload adjust, and damper adjust. Seems simple to me.
