NimBoy
Would a Type R Grill fit a Non Type R? (Facelift and Prefacelift)
This.BlueVTEC said:No mate the facelift has a much pointier bottom, which leaves nasty gaps between the grill and bumper. I will try and find a pic .
could beexec said:Havoc maybe your friend changed the bumper too, otherwise there would be gaps,no quetsions about it.
Thanks, that confirms that FL model has only front fogs modified and aerialShane said:Yes it is possible, there's absolutely no gap. I've done it myself.
There is always a gap, it's obvious. The two grills are quite different shapes, with the facelift being quite a lot more pointy at the bottom edge, and with shorter sides - which is very obvious even in that pic above! Look how the short edges stick down below the bonnet line! And you can see the big gap on the bottom edge where that grill isn't pointy enough to fill the space.Shane said:Yes it is possible, there's absolutely no gap. I've done it myself.
