Boot won't open !
DJX1Y
west yorkshire
Accord EX GT idtec
I tried opening my boot (saloon) and it won't open via micro switch( button in boot ) or by trying the button in the door. But it will open the boot via key fob
Any ideas what could be wrong !?
Thanks in advance for help/info
Marktypes
Newcastle
Accord type s
There is an isolating switch in the glovebox , try that .... Caught a few of us out before ;-)
vile
T A Terminator
Staff member
Bristol
8th gen 2.4 Manual
Yep top right hand side of glove box
Buffalo44
Lancashire
Honda Accord
Hi All, just signed up to this forum as I am experiencing exactly the same problem. I'll check this out and fingers crossed this will sort it. Cheers
TKR
FIN
Accord i-DTEC CW3
Same problem, but in tourer with power tailgate. Everything else is working but outer handle switch does not do anything. Is there also secret switch somewhere? Is it difficult to remove outer handle switch? Any tips?
Hutch532
Glasgow/Elgin
I-DTEC 2.2 EX Tourer
TKR Yeh, if you jump in the boot from a back door, remove the trim at the back and the lever is visible, flick that and pop opens the boot. Check the door window switches in case one has failed and its preventing the tail gate opening, I had this exact issue.
impne
Cold North East
Tourer type s
I just had same thing on tourer.
Tourers don't have the switch in the glove box so more than likely the passenger window switch is faulty
After the boot started to intermittently fail the window and mirror on the same door went
Changed the switch under warranty and all good now
I this to buy they are a bit shy of £300
TKR
FIN
Accord i-DTEC CW3
Outer handle switch was faulty. But now something else.,,
Few seconds after starting engine, tailgate opens. You can hear short electrical motor sound (probably from the lock motor) from the tailgate and after that you can see the tailgate open light on the dash. Tailgate do not open fully, only enough to ignite the light on the dash. Car has power tailgate. What could cause this? Everything else is working fine and this appears only when all doors are unlocked (remote double click done)
freddofrog
won 16.4k on Euro lottery :)
Off abroad
TBD
yes the sound will be from the 'lock motor' aka "closer unit" , on the 7th gen the outer handle sometimes sticks slightly causing similar problems, so it sounds like there is still an issue ***ociated with the outer handle.
When you say "outer handle switch was faulty", what/where was the switch ? AFAIK the switch is built into the "closer unit"
TKR
FIN
Accord i-DTEC CW3
I mean switch/handle that is located in tailgate. You press it if you want to open tailgate manually outside the car. Earlier that switch was faulty. I took it off, measure it with multimeter and there were no contact at all. I Install new one and everything worked fine almost a year. Bad luck if it is faulty again. But anyway, I will check it again.
sorry my English
freddofrog
Off abroad
TBD
Not your English, my memory LOL
I had to check on the circuit diagram, the switch that the outer handle 'trips' is not built into the 'closer unit'.
As you describe, it is a separate switch. Same on the 8th gen.
I guess that the switch is possibly 'vibrating' such that the controller informs the 'closer unit' that someone has pulled the outer handle. If the outer handle is pulled, the 'closer unit' will open the latch but the motor in the roof won't raise the tailgate (because if the outer handle is pulled manually, it is expected that the tailgate will be raised manually).
TKR
FIN
Accord i-DTEC CW3
Working well now. Outer handle was faulty again. Needed to change at random because testing with multi meter did not show any malfunctions. Without any previous experience and hint might be very difficult fault to find. Thanx freddofrog!
honda_saj
london
honda accord
Glad all sorted now
JulesCT
Buckinghamshire
ACCORD I-DTEC EX 09
It has started happening to mine, a 2009 saloon model. Then it worked for a day or two and went back to not working. Going to search for that isolating switch in the glove box.
