Brakepads?
dejv
att
Accord 2006 I-CDTI
Any recommendation on what brake pads for the front to get?
Ferrodo
EBC normal
EBC Greenstuff ?
Accord 2.2icdti 2006
Been running green stuff for a while.....pros low dust....cons.....noisey and low grab at slow speeds....just changed for Blueprint when the EBC pad detached itself from the backing Blueprint are much quieter and the performance in normal driving much improved..
What are you after? enhanced performance? Or just OEM replacement?
If enchanced Performance go for the Ferrodo DS2500 Pad. They are excellent and offer very good bite both in cold and hot conditions (track day pad)
If OEM - the best is genuine honda OEM. They are not as badly priced as you think.
Check Cox website or speak to HH
http://www.coxmotorparts.co.uk/2003-2008-accord-brake-pads-discs-c-14_35_570.html
Blueprint is an OK alternative to OEM if price is an issue.
I had oem and never had problems so its an oem replacement, my driving style is normal (sometimes towing)
I was just looking at different options as locally I was quoted €140 for oem and €37 for ferrodo ( I don't live in UK)
and ideally must not be more dusty than oem :p
