Bushings
ABZ
Accord 2.4 Type S
Hi All. I'm trying to identify a part but have no idea what it is called! Recently had car on ramp and identified play in front bushes or bushings....or even ball joint! It was a rounded rubber part which looked like the 1st one out of a set of three in a line behind the front wheels. The car is pulling to the left after many tracking attempts and the mechanic identified this part is a potential cause. Sorry for the confusing post but appreciate any thoughts on what this part is so I can order replacements. Thank you!
F6HAD
Affiliate / Co-Founder
Staff member
Halifax
2009 Accord IDTEC
Are you referring to the compliance bush?
ABZ
Accord 2.4 Type S
F6HAD thanks I think that rings a bell. I've Googled the pic and that looks like it. Do you know how much labour time a replacement on both sides would roughly take? I might try to jack car up and take a closer look
F6HAD
Staff member
Halifax
2009 Accord IDTEC
Probably £30 a corner for labour at most garages. The bush needs to be pressed in with a hydraulic press.
