Check System sign
Kool Keith
London
Accord i CTDi 2.2
Hi all
So a couple of nights ago I had to run the shop, it's a short drive, I got there everything was fine.
I got back in my car turned it on and it was in limp mode with the check system symbol. I drove around for a bit and it went out of limp mode. But the symbol was still there. The next day I started the car just to check, it seemed fine no limp mode but the symbol was still there. Has anyone experienced this before?
F6HAD
Affiliate / Co-Founder
Staff member
Halifax
2009 Accord IDTEC
You just need to plug it in and have a diagnostic scan run to understand what code is present.
Kool Keith
London
Accord i CTDi 2.2
Ok I bought a OBD the code p1384,which from doing a quick Google search it may be the glow plug.
Kool Keith
London
Accord i CTDi 2.2
The car is still driving fine and hasn't gone into limp mode, can I still use the car? I have to drive down to London (120mile drive)tomorrow and I prob won't be able to get hold of my mechanic until thursday
F6HAD
Staff member
Halifax
2009 Accord IDTEC
Yep that’s glow plugs. Most likely you will have a hairline crack in one of your glow plugs but it won’t show up on visual inspection. If you change them please use
Genuine Honda. Aftermarket are known to give errors due to a different resistance value. Car is safe to drive by the way
