Yesterday after leaving the petrol station I couldn't select any gear prior to that the gears were stiff but selectable the night before I had some juddering while driving.
Checked fluid and was really low topped up and no joy the clutch pedal is not springing back up ?
About four months I replaced the clutch master cylinder along with clutch pedal and fresh fluid didn't have tools to strip so will look at tomorrow what are you suggestions I will obviously re bleed to see if that works also there is a lever by clutch slave cylinder anyone know what that is for ?
