Clutch Squeaking
eleveneleven
Bolton
Accord 2.0 2007
So along with the power steering coolant pipe dumping fluid everywhere, I've noticed the clutch makes a squeaking/creaking sound when pressed in. Doesn't seem to be affecting the gear changes but doesn't sound very nice. Just wondering if I should be concerned about it, any ideas what it could be?
Car goes in on Wednesday for the replacement cooling pipe, is the clutch noise also worth mentioning to the mechanic?
Big thanks guys for your help with everything so far by the way.
There are old threads mentioning this problem, with various solutions mentioned. Use the search function above to locate them.
Good morning Eleven Eleven, did you find a solution to this problem please? My Accord is doing exactly the same.
