Driveshafts or something else?
Ilmas
Honda Accord
Hello everyone.
I own a 2.4 saloon manual.
I've been feeling alot of vibration from the floor and steering wheel at high speeds on motorway.
Not steering wheel shake like a wheel balancing issue.
Steering wheel vibration is similar to how a mobile phone vibrates.
No noises.
Slightly bouncy ride
Car was previously SORN for 5 years then MOT'd last year, passed with only brakes as advisory.
Then I purchased this car
Could this be driveshafts wearing out? Or wheel bearings?
Tyres are nearly new. No buckled alloys either.
Stevearcade
TA Friend
Staff member
Eastbourne
2003 Accord CM2
It'll be the shafts. It's well documented on here that a harmonic dampener on the shaft get moisture build up under it, corroding and eventually snapping the drive shaft. The biggest telltale sign is a wobbling steering wheel. Best to just get both front drive shafts replaced.
Ilmas
Honda Accord
I don't really have a wobbly steering wheel, its more of vibration like a mobile phone vibrating.
And its only at speeds of over 50mph , vibration becomes quite a lot on really rough roads.
Then lessens on smooth surface.
Forgot to mention, when I'm in a lower gear and higher up in the revs the gearknob starts vibrating too, alot more than normal at lower revs
Stevearcade
TA Friend
Staff member
Eastbourne
2003 Accord CM2
Yep... The still sounds shaft related. Have a thorough study of the shafts, especially around the harmonic balancer. Look for signs of corrosion. When mine failed, it failed there and clean snapped itself in two. With the harmonic balancer removed, it was clear corrosion and rust had reduced the shaft to about half its original thickness, but was concealed from view by the balancer.
Failing that, get under the car and give them a good wobble. There should be next to no play in them. If there's movement, the actual CV joint is worn out. Either way, the shafts will need replacing. I originally went with blueprint as I was strapped for cash, but they only lasted 18 months, as the CV joint wore out. Eventually replaced with uprated after market shafts designed for up to 400HP. The difference in ride quality was night and day. However, mine was lowered, which was probably why the blueprints failed so quickly, as there was extra strain on the CV joint. If yours is stock height, you might be OK to save some money and go with blueprint parts. I think OEM were about 500-600 for a pair when mine were replaced.
Ilmas
Honda Accord
Thanks for detailed reply.
I will check driveshafts as soon as I have time.
I'm planning to keep the car for a good few years and do some mods so don't mind paying extra for uprated shafts
Where did you buy these from? Insane shafts?
You said difference was night and day when you changed to 400hp shafts, in wich way did it improve? Like better handling?
Car is not lowered, just standard.
Stevearcade
TA Friend
Staff member
Eastbourne
2003 Accord CM2
Insane shafts, yeah. Just solid feeling. Like compared to the tired shafts that were on the car, these felt tight, you know. No play in the cv joint, better quality bearing in the CV joint and so on. The most noticeable thing was smoothness when you start moving from stationary and the car feeling more planted at speeds (mainly because the vibrations had gone).
Ilmas
Honda Accord
Ok thanks.
I've got my MOT in about 2 weeks so I might not be able to get Insane shafts delivered on time.
Looks like I'll have to wait and see what happens at the MOT
MrMwa
Honda Accord
I've been reading the forums and driveshafts seem to be a common issue on the 2.4s not sure why.
My previous 2.0 had 147,000 miles on it and didn't have any driveshaft issues and I was hammering nearly all the time.
Let us know what happens after MOT
