Exhaust manifold leakung
Richard B
Australia
2006 Tourer
You have checked the other threads on this subject?
I'd go to somewhere where someone has reported a good (i.e. warranty) experience.
Stevbpool
Blackpool
Honda accord
Thanks for that got a good garage always use will let them get to bottom of it hopefully just gasket no loss of performance they noticed when had service on Thursday last
Richard B
Australia
2006 Tourer
If it is the original manifold it is highly likely you have a cracked weld, which Honda has admitted is a manufacturing defect.
Flash
N.W Kent
Honda Accord tourer
discoverd mine at 100,000miles, guy in the garage said it would take 2 days to fix, he has the same model (but in a salon) he advised leaving it to see if it got any worse,at 170,000 it is the same,no lack of perfomance,just a bit of exhurst smell for a minuet or two when starting in the very cold,saved a few hundred quid on the repair ;)
Jon_G
No Longer Active
Nr Ludlow, Shropshire
2005 Tourer i-CTDi
Exactly the same here.
ToothlessDrunk
Berkshire
2.4 TypeS estate
It's a simple but long winded weld job , thats the reason for the two days . When I weld cast manifolds etc ... prep , preheat , weld and then wrap it up in a couple of fire blankets and sit it in the corner overnight .. Unwrap and give it the crack detection treatment .. if bad ..do again , if good ..charge the money and call it a job done .
burbleboy
Scotland
Accord 2.2 2007
TheJamMod said:
Phone Honda and they'll swap it for free in most cases.
Ive heard they won't. Lead to believe that only thing Honda offer is discounted parts and labour. £580 if i remember correctly and only up to cars 7 years young or 100k...whatever comes first.
Mine has 87k in the clock and i can smell fumes now **looks skyward**
TheJamMod
England
Accord
Mine wasn't in the 7 year warranty bracket.
I went to Honda dealer to have the manifold crack confirmed.
I phoned Honda up.
They called me back and confirmed they'd do it for free.
Booked with dealer.
Doesn't hurt to try. Just be nice. :)
Leggy6
Surrey
Accord
I have just had Honda confirm that my EGR Pipe has a crack, sending fumes into the cabin
Is the EGR Pipe covered in Honda's extended warranty? on a 2011 2.2 Diesel (The Main Dealer has said no)
Jon_G
No Longer Active
2005 Tourer i-CTDi
Honda issued a TSB (TSB SL-02-008-00 dated 01-09-11) for this problem. This link claims that this is covered by an extended warranty, so either try another dealer or contact Honda UK...
http://www.civinfo.com/forum/honda-accord/62577-8th-gen-accord-warranty-extension-egr-pipe-crack-accord-idtec.html
This subject should probably have it's own thread.
Leggy6
Surrey
Accord
Thanks for the info Jon, I have been in touch with Honda UK and they said that they would get back to me within 3 days
Fingers crossed!
Will let you know how I get on.
burbleboy
Scotland
Accord 2.2 2007
Very helpful posts.
Thanks for all the info.
I shall book my car into Honda for official confirmation of exh leak then contact Honda UK.
Mine is sitting at 87k so that should be a positive towards getting it done hopefully!
burbleboy
Scotland
Accord 2.2 2007
Also....my headlights now started to get condensation in em...so I shall be asking if mine has had the recall for new headlight clips, when its in Honda!
Leggy6
Surrey
Accord
Just got a message from Honda UK to say that the main dealer will be in touch to change the EGR pipe under warranty
Pity the main dealer did not offer this in the first place!!
Once again Jon thanks for the advise & link saved me £600.
Jon_G
No Longer Active
2005 Tourer i-CTDi
Glad it appears to have worked out!
