TheHole
Hello All .
Its been a while and i hope you are all well.
This is on behalf of my parents as their accord is being a bit of a pain.
1) we cant get any hot air out of the driver side dash vents. This is even the case if i shut off all the other vents and just run it through the one near the drivers window.
2) we cant get any hot air out of the windscreen demister when the dial is moved to demist the screen.
Another issue is that i took the car to get the aircon regassed and they filled the system up but it doesnt work... No leaks where detected but i presume the compressor unit has failed.
Any advice if i should take a used compressor or buy a blue print part?
Adam
Adam
