Headlights - Are they Xenon or Halogen
TiFicate
Honda Accord 2008
Hello, So I have 2008 Honda Accord 2.4 (europe)
and can't for the life of me understand what kind of headlamps do I have,
are they Halogen or Xenon?
(ps. the car has headlamp washers installed; it doesn't have headlamp adjustment switch in the pit)
(pss linking to the reddit post, since this website does not allow uploading the photo here :/)
Only the Pre facelift 2.4 Exec came with factory xenon’s in the 7th gen, and only the Type S 180 has them in the 8th gen. The JDM Euro R also has them. Safe to say yours will be halogen whichever generation it is.
I missed the bit about lack of adjuster, in which case agreed you probably have xenons. If it’s a pre facelift exec however I’m pretty sure they all had washers. Easiest way to check, just lift your bonnet and look at the rear of the headlight. If you can see a ballast then it’s xenon.
Thank you for the information! WIll try to check in the morning
