s-preston87
Hi peeps,
So recently I have noticed three things:
1) When driving either cold start, warm or cold engine the car seems to hesitate. When i get the biting point and set off it sounds like the car is on the verge of stalling but not quite, and just as it does there is a slight vibration and metallic clatter from under the car. The main concern with this is the close to stalling feeling... cant seem to work this out.
2) First start of the day I usually let the car run for a few minutes before setting off for work, however the car seems to be very jerky when driving. example. I will accelerate slowly from first and then change into second but if i accelerate and then ease off the gas it will then jerk quite a bit. Its hesitating and then adjusts as the revs go down.
(The revs are round 1300rpm when cold starting)
3) After the car has warmed up thoroughly after a good drive if i stop the car, regardless in neutral or in gear the car starts to idle a little low and rough - roughly 650rpm and the car seems to shaking, the front passenger seat seems to be shaking and it can be heard from inside and outside the car. .
The strange thing is that if i put the fog lights on then the revs increase a little the roughness levels out and becomes steady and smooth again.
A major service will be done in a few weeks inc all fluids (except transmission fluid)
Valve adjustments will done in a couple of days by GrinSpeed (been there a few times)
the Idle Control Valve was adjusted a few months ago
The throttle body has been cleaned - was a sticking a little prior to cleaning with TB cleaner and a rag
LUK clutch kit installed 4 months ago - Redline MTL90 oil - no issues after installation.
Accord sport 2.0L - 2005 pre facelift - 107k miles - no mods apart LED 501 bulbs and head unit
Any advise would be greatly appreciated - thanks in advanced
