Honda accord. 2.0 vtec
Keijab
Accord mk7
Hi guys my. Accord. 2.0 petrol.
2007. Saloon. Has just stsrted. Juddering and won’t get any. Speed of past first gear
Struggling to ‘ breathe. ‘ and. Jolting / juddering. It’s been fine tday.
My first Honda.
What shud I be looking. For to begin. With.
Dirty fuel. Fuel filter. Hope it’s not the fuel tank again. ?
Sounds like a fuelling or intake problem, could be a misfire. Scan it for any codes in the first instance.
Hi guys. I’m looking to use larger wheels and tyres. On my mk7. Saloon
In terms of better traction and handling road holding.
Wud I see a good benefit. Fro. Using 17 inch wheels. 18 maybe. Instead of these. Weedy 15 inch. Originals. ?
Any suggestions. Guys
I wouldn't bother if it is better handling you are after unless you have deep pockets.
Remove all excess weight from the car, buy a decent set of tyres to fit your current wheels and get them dynamically balanced by a professional outlet.
Just a thought, were 15" standard on the Vtec ? I've only seen 16" tyres on checks when buying replacements for the tourer.
if its for handling you want wider wheels so you can get wider tyres on it
Wider wheels/tyres would only exacerbate fuel consumption unltil the underlying issue is fixed.
