crespo
This is the process to manually code your remote function on your key,
If you have a dead battery and your key has forgotten the code when you replace your battery this info will save you a trip to the dealer and parting with some cash.
MAKE SURE ALL DOORS ARE CLOSED.
1/ Switch ignition on and press lock
2/ Switch ignition off
3/ Repeat 3 times, the locks should cycle, Then press lock on the remote and the locks should cycle again.
IF YOU HAVE ANOTHER KEY PRESS LOCK ON THAT KEY AS WELL.
Finally remove the key from the ignition and test.
You should now have a fully functioning remote key,
this will not code the immobiliser, you will need a dealer for this
