I just got a 2009 8 Gen Honda Accord i-dtec Ex which has done 106000 miles @ £5k from an independent dealer, the car was a dream car to drive, after two days, I started noticing a couple of faults which I did not see before buying the car. 1st the driver side speaker is blown, both cigarette chargers are not working, a small crack on the widescreen. All these I can fix without breaking the bank. but the major problem is I was at the traffic light and wanted to pull away and the clutch pedals won't come back up. I had to use my hands to pull it back up. I thought is was a one off, but it has happened almost 5 times in a week. The clutch does not slip and seems to work fine until it stays down and won't come up especially at traffic stops when I have to press it down for a while when 1 gear is engaged.
I called the dealer he said it may be because the car was not driven for about 4 months and there could be some rust at the pedal spring or maybe the it needs bleeding. I am a bit worried that it may be the entire clutch system that needs replacing and I am sure it can cost up to £1k to replace the entire clutch system. The car has mechanical warranty for 6 months. The dealer as me to bring it back so he can have his mechanic check it out. If it happens the entire clutch system needs changing, I would prefer that being done at Honda as I have read that most garage can't really fix it right. I will take it to the dealer tomorrow and see what he says after all as I do not expect to pay for a new clutch after paying £5k cash on a Honda Accord. What are your thoughts?
