It's back !!!
bobfish45
accord 2.2 estate
Sadly my pleasure at sorting things out didn't last long, loss of power is back with a vengeance. This time it went into limp mode and wouldn't reset using on/off method. It did however reset after a 15 min rest.
I have been able to obtain fault codes now, 7d02, intake air temp sensor, 1 circuit high voltage, and ac04 boost pressure lower than expected.
Intake solenoid valve is £250 and mass airflow £431 so it makes the car uneconomical to repair really with whats already been done, anyone any car saving ideas? :(
F6HAD
Affiliate / Co-Founder
Staff member
Halifax
2009 Accord IDTEC
Your intake sensor error is most likely from the MAF being disconnected, probably when your manifold was being changed.. and the boost pressure error points to the original problem of a sticking turbo. I know they fixed it for free but they didn’t actually fix it..
bobfish45
accord 2.2 estate
Well, no parts needed ! Took out and cleaned mass airflow sensor, and intake sensor, now the car accelerates like it should ! No hesitation and full power when foot planted, it's hard to believe that something so simple could have such a drastic effect. Hopefully it will stay as it is now. :)
F6HAD
Staff member
Halifax
2009 Accord IDTEC
Fingers crossed Rod. A faulty or dirty MAF wouldn’t trigger a low boost error though. Sounds like intermittent sticking vanes, personally I would give it a regular thrashing to keep the vanes moving freely.
bobfish45
accord 2.2 estate
Thanks chaps, it will be driven as it should Fahad, with attention to the full rev range ;) See you soon I hope.
