K20A6 engine play
w00dman
Coimbra, Portugal
Accord
Hi,
https://youtu.be/XQyoAPqM3rE
Is that play on the engine normal? The video was taken with the engine cold.
My clutch has 174000miles and I will replace it soon. I will repair my power steering pump to. If you listen you will know why.
Is that normal or may have a bad engine mount? can some one gess who is he?
I would say no, given the mileage, check rubber mounts for wear/crack etc.
Hello folks,
Maybe found the coulprint. I've got my car parked at my garage for a bad coils. As it will take some days to arrive I've tooked the intake manifold out to give it a clean and what a big pile of sh** was in there. Then I've looked downs and saw the front mount was easy to access.
Before took him out, I've tested the vacuum line and what? No vacuum on him.
Rough idle and vibrations just from this tiny hole :D
Now I need to get a full new motor mount.
