Hi guys!
Couple of months ago my engine started knock when running on petrol (car is adapted to LPG).
I suspected from the knock sensor, and finally I got one to replace the the old one.
Today, when I started to replace the old one, it broke in my hands as soon as I touched it, so I guess it should be the culprit...
Any way, I was under the car trying to remove the old sensor, but without success. Later in the afternoon will try again and put some WD40 and see if it helps...
As anyone replaced the knock sensor? If so, were you able to remove it without removing the intake manifold?
I am not really in the mood tho remove the intake manifold, but I am thinking that I will have to do it...
