Maintenance codes
Maudlin
Bulgaria
2009 Honda Accord
Folks,
regarding the maintenance codes, what is the way to see the time a code is due?
I mean these are the codes:
Symbol Maintenance Items
A Replace engine oil and oil filter
B inspection service
2 Replace dust and pollen filter
Inspect drive belt
3 Replace transmission fluid
4 Replace fuel filter
Inspect idle speed
Replace spark plugs
5 Replace engine coolant
7 Replace brake fluid
8 Replace air cleaner element
9 Inspect valve clearance
Couple of questions:
1. What do the numbers which appear under the code? Kilometers? Days remaining to the next change?
2. How do I skip from code to code? I mean if I have the B code on the display, how can I see the other dues?
3. What does B "Inspection service" include? What kind of services?
4. If you change something before it is due, how do you recall the code in order to reset it? eg: You have just changed the engine coolant, how do you recall code 5 on the display?
Thanks.
