Mk4 - Where to buy ABS sensors
antharro
Dorset
I have at least one failed ABS sensor on my Mk4. Honda want £260 each which is ridiculous. Any idea where I could pick them up cheaper?
Are they any cheaper in the States?
Edited to add - are the sensors the same across the Mk4 range - ie, coupe, saloon, estate, 2.0 and 2.2?
you can google the part number
start here https://www.lingshondaparts.com/honda_car_parts_catalogue_C01.php
you eventually come to a page of thumbnail drawings like this - Accord 1992 2.0 for example
https://www.lingshondaparts.com/honda_car_parts_block_selection_C30.php?mod_01=5243
front ABS sensors are usually in the "knuckle" drawing - items 9 and 11 in this one
https://www.lingshondaparts.com/honda_car_parts_selection_pfk.php?block_01=17SM411&block_02=B__2700&block_03=5243&block_05=hcr
rear ABS sensors are usually in the rear lower arm drawing - items 39 and 40 in this one
https://www.lingshondaparts.com/honda_car_parts_selection_pfk.php?block_01=17SM411&block_02=B__2900&block_03=5243&block_05=hcr
you'll notice that the part numbers begin with "PFKL" which are not Honda part numbers, to get Honda part numbers remove "_pfk" from the URL of the page with part numbers
Hi, not long had my gen4 coupe and I'm fixing it up. I've found all the parts from the states are cheaper and mostly available. But the cost is unfortunately the shipping and import charges so it probably works out not much different in the end.
