No Idea whats going on .. Fans wont run....2.2 Accord IDtec 2009
Kene
Honda Accord
Hi , have a 2009 2.2 iDtec accord , noticed fans not running , changed Thermostat , Radiator Coolant Switch , will now pull water pump and replace , does anyone know where to pull a work shop manual on the N22B IDtec engines .....can not find one ... anyone had the same problem , fuses all good , relays swapped around with horn Relay and all work ,, just no idea whats gong on ???
Service manual is here
Alternatively you can download a local copy:
Thank you , change Pump , Thermostat , Temp sensor 2 , coolant ... hope its sorted ...
