Alright guys,
In terms of cold air, directional adjustments, blowing power etc, all works fine. I just don't get hot air, which as the rain's coming down a lot is a nightmare as I'm having to clear the mist with cold air, freezing my nuts off, inducing mist on the outside of the glass due to it being so cold and then needing to use my wipers... Happy times!
I can't see a fuse relating to the heater element in the handbook. I don't know if there is a relay instead. Does anyone have any experience of this and can they advise me on next steps. I've looked on LINGS to see for any possible obvious points, but can't see any particular part that I'd say, "ah, I bet that's gone!"... :unsure:
Like I said, it's not like a temp sensor issue, it's not an issue with the fan or motorised vent adjusters. Everything works exactly as it should aside from the lack of heat. It's a total lack of heat too. Not not being warm enough. It's just cold! I'm 99% sure it's purely that the heater element isn't heating.
Thanks in advance.
Thanks in advance.
