Noisey windscreen wiper motor
Mr Sparkle
Aberdeen
2.2 ES GT Saloon
Hey folks, is it normal to hear the motor whining away through the dash during operation? I’m not talking about the blades themselves moving across the screen.
TIA
Bounder
Co Cork Ireland
Accord Type S CW3
It could mean that the motor is under load more than it should be, the wiper pivots can get corroded and cause a lot of friction, try disconnecting the spindle from the motor drive marking it so you don't lose your position and seeing if the wipers are free to move, if they aren't then you can disassemble and lube the shafts and that should help a lot.
matsalka
Estonia
CU2 K24Z3
Took mine apart and the wipers move just fine. It's the motor itself that makes that loud-ish sound you can hear inside the car.
Bounder
Co Cork Ireland
Accord Type S CW3
Are all the rubber mounts on the motor OK?
If any of them are failing the motor can touch the steel and transmit noise.
