Hi guys,
For a while ago, when the heat comes, I have an excessive noise coming from the front brake pads on bad roads or "stone roads". As soon I touch the brake pad, even so slightly, the noise goes away...
First I suspected of worn slider pins, now I am suspecting of defective pad retainers (those metal clips that goes between the brake bracket and the pads), or even brake pads that doesn't follow Honda specifications by 100%. The brake pads I have are from Pagid, and so far they have been great! The other ones that I had(EBC, IIRC) were also rattling like crazy on these bad roads...
Today I took close look on the brake pads and noticed that on top (and bottom) of the pads, there is a gap of about 2/3mm between the pad and the pad retainers. Take a look on the following picture, it's the gap between the two red arrows.
Can anyone take a picture of yours to compare, or just look at them and see if they have the same gap?
