Hi people do you guys have to top up oil between services or not ?
As I have had my oil light flash up, I topped up about a month and just saw light flash again.
I added 2l have done around 1500 - 1800 driving around london where we have a lot of Start stop driving I have just checked the dipstick and oil level is super low although the oil light has not flashed again I will top up and make note of mileage ? Any suggestions I do drive the engine hard at times.
I can't see any oil leaks or puddles although I see little bit of smoke if I throttle hard in first gear. Will top up and write date and mileage on bottle and update
Anyone else with type s 2.4 please let me know I am topping up a quart (0.9I) around 1000 miles around london ? According to internet research this.is normal but I am still not fully satisfied
I'm topping up apprx 1l every 3000km or so. If driven hard (above 5000rpms), maybe 1,5liters. Unfortunately, this is a very common issue for the K24 engine, and as long as the car is running fine, I won't be changing anything. I've used different brands (Eneos, Mabanol, Castrol), 5w30, 5w40 and 10w40 in the summer - no difference.
i do drive the vehicle hard someitmes but i still think 1l to every 1000 miles is too much oil consumption, compared to your 1800 miles. Although i am in london so a lot of start stop driving and traffic jams.
I would not mind if i had to top up every 1500 or so, is most of your driving on higways ?
I have to use trip b to keep and eye on mileage so i can topup.
People just a quick update after two oil changes and oil filters also changing oil to 10w30 semi synthetic I am topping up oil less often getting about 1500 miles without top up. seems some dealers are doing services with mineral oil. My final oil change will be 0w30 fully synthetic.
