OSRAM Night Breaker vs HID
which bulbs headlamp?
  • HID KIT
    Votes: 3 60.0%
  • Osram Night Breaker
    Votes: 2 40.0%
  • Total voters
    5
dejv
att
Accord 2006 I-CDTI
Which would you reccomend HID kit or osram night breaker ? please state also reason below :)
(also is the main beam and dipped same h1 ?)
Osram are nice and bright but nowhere near as bright as HID depends what you want, just bright lights or blinding lights
I want white lights and if possible better lightning for night drives
I have Osram night breakers and they do provide a crisper more whiter light. Better output than stock OEM bulbs.
Although they tend to last a year or so.
Bulbs are easier and hassle free. Simple bulbs changes.
They dont provide the same output as a xenon bulb, xenons are miles better in light output.
Osrams - positives
-Cheap upgrade
-Easy to change
-Provides better output than stock oem headlights
-Auto headlights upon start up is fine for use
negatives
-Light output not as good as HIDs
-Light is not as white
Xenons - positives
-better whiter light output
-uses less power 35w as suppose to 55w
-ballasts all fit within headlight cavity - providing you buy the slim style ballasts
negatives
-alot of cheap kits out there - hard to buy quality and reliability
-takes time to install - headlamps need to be removed - which means removing front bumper. although most kits are plug and play
-If anything goes wrong with the kit later - headlamp and bumper need to removed to find the issue
-if a normal bulb blew - a bulb is easily changed
-Dont think you can have xenon hids on auto whilst starting the engine
-Not sure if beam pattern will be perfect
-Will fail an MOT - due to no self leveling system (not the beam height adjustment) - different type of self leveling system
-Wont be road legal
