Power Steering oil and Anti Freeze
Acowner
J23M1
Accord
Hi
I don't have a owners manual, can anyone advise on the power steering oil spec and anti freeze spec for 2007 Tourer 2.2 diesel, had a search round the usual suspects of oil suppliers but none of them can confirm the actual specs. and recommended quantities
I suspect a universal anti freeze for ally engines will be sufficient.
Thanks for your help
rob88
Brighton
Accord 2.2 icdti,
Hi, I just use genuine Honda fluids and order through Cox spares.
For coolant Manual says all season type 2, it's premixed 50% antifreeze 50% water. System has many aluminum parts that can corrode if improper coolant is used.
You definitely want genuine Honda PS fluid, manual says Honda ps fluid V II or S. Manual says any other ps fluid will damage system.
This is from the manual for a 2004 diesel.
Hope that helps somewhat.
