Rear brakes servicing
Bonzo
2005 2.0 SE manual
Can somebody help me concerning the rear brakes on my 2005 2 ltr saloon,,
I am about to replace discs and pads on my car and whilst I was looking at them closely it would appear that the concertina type rubber seals on the slider pins are not that great.
question is can someone send me a link to a website where I can purchase these.
Thanks in advance for any help .
John
markofdown
Honda Accord icdti
Hi. I have a 2007 diesel saloon and changed the rear brakes - discs pads and calipers last week, your car should have a similar setup. The slider pins were corroded and seized on one side and the rubbers split. I got replacements from Ebay @ £13 for both sides. The kits included the slider pins, with a sachet of grease , new rubbers and retain bolts. Remember to clean out the hanger where the pins go of old grease - I found cotton buds good for the job. Hope that helps you. Regards Mark
Bonzo
2005 2.0 SE manual
Thanks for the reply Mark,,,would you have a link for this?
Accord127
Accord diesel
Can you help me ple, i also replaced the rear rotors and pads, but not after 350 miles the outer side of both pads is half touching the rotors, inner side is fully touching , some people say it will be fine after few hundred km ?
Bonzo
2005 2.0 SE manual
Did you clean and re- grease the slider pins? Also fully apply the handbrake a few times.
other than that I don’t know
Richard B
Australia
2006 Tourer
There was likely some corrosion on your brake piston that, when you pushed the piston back in to fit the new pads, is now interfering with smoothly sliding past the seal.
You need to have a look at that. Pull the piston halves apart and inspect behind the dust deal. Some related info, and photo here.
