rear toe adjuster bolts are stuck
Accord127
Accord diesel
i took my 2005 accord for rear wheel alignment, but the bollts of rear control arms are stuck, the nut comes off but bolts are impossoble to move, i applied wd40 , hit hard with big hammer, heated them but the bolt doesnt want to move a milimeter even. any special trick to loosen/remove them, i bought replacement control arms and bolts, but still unsucessful in removing the old onebolts from control arms , any special technique ?
Looks like brute force and a reciprocating saw
Hi,
I've got the same problem.
Any joy?
Also, do you have the part numbers for the rear bolts? My mechanic told me there are two bolts per wheel, one for the camber and the other for the toe. Honda dealer just sent me a picture with no part numbers.
