Replacement headlights
ephercius
Malta
Accord i-CTDi
hello all,
anyone know where i can buy these headlights in RHD please?
All the models that i am finding are LHD
thanks in advance
that's a very tall order, they may be made in china or taiwan, but are only sold in the canada and the states. worth mentioning the projector takes a d2s bulb so if yours has the stock H1 projectors you'll need a HID conversion kit as well
you can do a rhd projector swap if you're dead set on these, but it doesn't look like the oem stanley projector, so you'll have to fab some brackets and then align everything. it could be a fun weekend project ;)
I am not worried about changing the connection and having a HID conversion installed.
ATM I am trying to source in Japan as I don't really want to buy a set and ruin it for nothing.
I'm not so good with these kinds of things if I cannot find information that will help. hehe
In projector headlights, the part that determines both the illumination pattern as well as the left or right bias is the shutter. LHD and RHD headlights have mirror image patterns of each other cut in the top edge of the shutters. As far as I can tell from the very few images of the actual Honda projectors I have seen (no one seems to pull them apart) Honda uses a curved sheet metal shutter that would take a bit of work to imitate, but aftermarket projectors might be easier to modify. It would also not be all that difficult to find 2 smashed up Honda headlights that have intact RHD shutters, and graft these in position inside and aftermarket projector of the same diameter.
A neat trick would be to mount the shutters on solenoids that remove them from the light path in unison with the high beams. You would end up with a lot more light output on high beam.
^the h1 and d2s projectors have the same form factor but are built different. both are clamshells though.
h1 has a loose shield held in place by a phillips or jis head screw on the reflector bowl side of the projector.
d2s has a shield integral to the lens housing casting
the projector lens itself is likely identical between the two, but facelift has a fresnel lens whereas prefacelift has a clear lens.
they measure 2.5in but are proprietary and other 2.5in lenses do not clamp onto the housing without invasive modification
I'll upload some pictures later if anyone's interested
adapter brackets do not exist for any popular 3rd party projector
If you have images of the actual parts I am definitely interested in looking at those.
First image is the D2S projector housing and reflector bowl - will take better pictures next time I have my lamps out - need to adjust rotation
you can see that the cutoff shield is not a detachable part on the reflector bowl but rather an integral part of the projector lens housing
the following pictures are of the h1 variant
fresnel lens and bulb holder - iirc a fresnel lens was chosen over a clear lens to reduce light artifacts and soften the cutoff line as to make glare less intense for oncoming traffic
reflector bowl and cutoff shield - the curvature is essential for cutoff focus as the reflector.. well, reflects light off and onto itself towards the focusing lens
and this is where it lives. projector ***embly can be taken out without splitting the lamp if you squeeze the opening into an oval
