adrenalinas
Hi guys!.
I have unpleasant issue for some time(maybe even from time i got this car). I have hard shifting from first to second gear... It seems that car stalls for a second when shifting(it is strongly felt when driving cold engine/gearbox and less when warm). I thought that it may be because of bad fluid. changed it but problems persist.
Can anyone suggest anything?
I searched a little bit and found that it maybe be because of malfunctioning (or going bad) linear solenoid.
I found that it may be part No5(only one with word linear) in picture http://japancars.ru/cat/honda/index.php?hmodtyp=5693,5694,5695,5696,5697,5698&npl=17S1A01&_nplgrp=2&nplblk=ATM0710 but manual says that it is "AT clutch pressure control solenoid valve". Can anyone confirm that it is the same valve I need to replace? where could I get it new?
Or maybe there is some other solution with this problem?
